| I just wanted to double check with others... So, exactly what pipes can be reused from a NA when swapping a TT and putting in a TT condenser? It looks like the low pressure hard pipes from the FW down across to the flexible compressor section need to be from a TT. Also, how about the flexible high pressure hose that connects to the compressor? It looks like there is a short metal pipe that connects from the condenser, to the flexible high pressure output hose to the compressor.
